Введение
Use this guide to help repair a faulty battery in the Oregon Scientific Meep! X2 tablet.
Выберете то, что вам нужно
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
Pull lightly on the ribbon cable to remove it.
Use your spudger to separate the battery from the adhesive glue strips and plastic film.
