Введение
Use this guide to help repair a faulty battery in the Oregon Scientific Meep! X2 tablet.
  1. Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device. You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device. You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Use the plastic opening tools to undo the clips around the edges of the device. Use the plastic opening tools to undo the clips around the edges of the device. Use the plastic opening tools to undo the clips around the edges of the device.
    • Use the plastic opening tools to undo the clips around the edges of the device.
  5. Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools. Pull lightly on the ribbon cable to remove it. Pull lightly on the ribbon cable to remove it.
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  6. Use your spudger to separate the battery from the adhesive glue strips and plastic film. Use your spudger to separate the battery from the adhesive glue strips and plastic film.
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  7. Use a soldering station to unsolder the battery wires from the motherboard. In the case of screen or screen sensor replacement, disregard desoldering steps.
    • Use a soldering station to unsolder the battery wires from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
Заключение
J'mel Henneman
Участник с: 20.01.2015
855 Репутация
Автор 8 руководств
Команда
USF Tampa, Team 9-1, Blackwell Winter 2015 Member of USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 15
За всё время: 1,055
