Введение
This guide will show you how to access and remove the mSATA SSD from both locations in the Origin EON17-S.
Выберете то, что вам нужно
Disconnect all peripherals.
Disconnect the power cord.
Lay the computer upside-down.
Push both locking tabs inward. One is spring loaded and will need to be held while removing the battery.
Remove the battery by pulling up on the tab.
Remove the component cover by removing the six screws with a 3/32" screwdriver.
Remove the screws from the bottom of the computer.
Remove the screws from the back of the computer.
Put on the electrostatic wrist strap and attach the alligator clip to a sturdy piece of metal inside the case.
You will see the mSATA drive in the lower right hand corner of the component area.
Remove the screw on the far right side of the drive.
The drive will rise up to an angle.
Remove the drive by pulling in the direction the drive is positioned.
Unscrew the two screws holding the hard drive cover to reveal the second mSATA bay.
Remove the hard drive by sliding it towards you.
Once it is free of the port, use a screwdriver to gently pry it from the bay.
Remove the small, silver, rectangular plate below the hard drive bay.
Remove the small screw at the front of the plate.
Pull the plate up and out.
Remove the small screw on the upper left of the hard drive.
The drive will rise up at an angle.
Remove the drive by pulling in the direction the drive is currently positioned.
To reassemble your device, do anything you did in reverse.
Еще один человек закончил это руководство.
