Введение
Use this guide to remove the blades from the blender in order to replace them.
First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
Flip the container on its side so that the bottom faces you.
Now rotate the bottom counter-clockwise to remove it from the container.
Now you will see the bottom of the blender blades once the bottom piece is removed
Flip the blender container on its side so that the bottom faces you.
Now, you can insert the new set of blades into the container.
