Выберете то, что вам нужно
Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
Locate the four 11mm screws in the circuit board.
Unscrew the four screws using the Phillips #1 screwdriver.
Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
Now separate the circuit board from the base.
You will see that the circuit board is still attached by a red wire and a black wire.
Flip the circuit board back over and desolder at the indicated points following the directions given here.
Now your circuit board is ready to be replaced. To reassemble your device, follow these instructions in reverse order.
6 участников успешно повторили данное руководство.
10 Комментариев
So, a question. Where does the spring go? I was fixing one of these and the spring fell out and I never saw where it came from.
inside 2 tubes that stick out opposite of each other just below the fan.
Spring goes on the one of the strips that slides back and forth....it has small end which goes in a small notched cavity of the plastic housing. Spring goes on that longer end of the stripe. See the picture in step 12...its popped out from the plastic housing.
conoces el orden de las laminas del circuito de velocidades…? agradecere cualquier sugerencia…
Awesome, this guide was really helpful in repairing my blender. Thumbs up for the author.
