Введение
How to replace faulty heating coils.
Выберете то, что вам нужно
Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
Take off both rubber feet using a small metal spudger.
Wedge a spudger under the feet and pull up to pop off.
Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
For this part, you might need to wiggle the toaster to get the outer shell off.
Once the outer shell is removed, rotate toaster so the back is facing you.
Use flat head tweezers and plastic opening tool to remove the top metal panel by prying the metal tabs upwards so they are able to slide through the openings and pull upwards.
Once top metal panel is unhooked. Lift and let hang off the side of the toaster.
Turn the toaster so that the faulty wire side is facing you.
Position the top 5 metal tabs to fit through slots .
Position the 4 metals tabs on the heating board. Found at the top right and bottom left.
At the bottom of the heating board, there are 2 tabs holding it to the rest of the toaster, pull those 2 tabs upwards to release heating board from the toaster.
There should now be 2 wires connected to the heating board that would need to be de-soldered to disconnect.
