Введение
This guide will show you how to replace the lever springs on your Oster 3905 toaster.
Выберете то, что вам нужно
Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
Take off both rubber feet using a small metal spudger.
Wedge a spudger under the feet and pull up to pop off.
Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
For this part, you might need to wiggle the toaster to get the outer shell off.
Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
Pull the metal spacer upwards to release from the toaster.
Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
Еще один человек закончил это руководство.
