Введение
Prerequisite only.
Выберете то, что вам нужно
Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
Take off both rubber feet using a small metal spudger.
Wedge a spudger under the feet and pull up to pop off.
Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
For this part, you might need to wiggle the toaster to get the outer shell off.
Почти готово!
Заключение
