Введение
The circuit board is the main control center of the blender.
Выберете то, что вам нужно
Use the prying tools to open the four plastic screw holes on the bottom of the blender.
Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
Use the spudger to detach the black wire from the circuit board.
Repeat for yellow wire.
Use the Phillips #1 to remove the four 8mm screws.
Use the medal spudger to detach the circuit board from the buttons.
Gently pull and release circuit board from buttons.
Еще один человек закончил это руководство.
