Oster Blend-N-Go My Blend Blade Assembly Replacement
  1. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: шаг 1, изображение 1 из 2 Oster Blend-N-Go My Blend Blade Assembly Replacement, Blender Bottle: шаг 1, изображение 2 из 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Replacement: шаг 2, изображение 1 из 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: шаг 2, изображение 2 из 3 Oster Blend-N-Go My Blend Blade Assembly Replacement: шаг 2, изображение 3 из 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Replacement, Blade Assembly: шаг 3, изображение 1 из 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
Заключение
Еще один человек закончил это руководство.
Paul Long
Участник с: 08/27/15
710 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 12-6, Blackwell Fall 2015 Участник USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 членов
Автор 5 руководств
2 Комментариев
I’m confused, these are the steps you have to go through every single time you use this blender to blend something. This isn’t really a “replacement” process here. If someone needs to repair a cracked blade assembly or buy a new one, how would they do that?
Alan M - Ответить
This process is not helpful at all. I followed as instructed but the blade is not moving at all?! What is going on? Pls provide better HELP INSTRUCTIONS.
Fareda Edwards - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 28
За всё время: 3,586
