Overclocking your eMac
Выберете то, что вам нужно
    1. Overclocking your eMac, Door Removal: шаг 1, изображение 1 из 3 Overclocking your eMac, Door Removal: шаг 1, изображение 2 из 3 Overclocking your eMac, Door Removal: шаг 1, изображение 3 из 3
      • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
      • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
      • Remove the single phillips #2 screw on the RAM door, and remove the door
      • The screw is captive in the door, so don't worry about losing it.
      Спросите у FixBot
      Добавить комментарий
    1. Overclocking your eMac, Bottom Screw Removal: шаг 2, изображение 1 из 1
      • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
      • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
      • On the bottom side of the eMac, remove the following screws:
      • A single 2.5mm hex screw
      • Two #2 phillips screws
      Спросите у FixBot
    2. Overclocking your eMac, Top and Side Screws: шаг 3, изображение 1 из 3 Overclocking your eMac, Top and Side Screws: шаг 3, изображение 2 из 3 Overclocking your eMac, Top and Side Screws: шаг 3, изображение 3 из 3
      • Remove two 2.5mm hex screws from each of the other sides of the computer.
      Спросите у FixBot
    3. Overclocking your eMac, Power Button Cable: шаг 4, изображение 1 из 2 Overclocking your eMac, Power Button Cable: шаг 4, изображение 2 из 2
      • Now, the shell can almost be separated from the computer.
      • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
      • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
      Спросите у FixBot
    4. Overclocking your eMac, Shell Removal: шаг 5, изображение 1 из 1
      • Now the entire shell can be removed from the computer.
      Спросите у FixBot
    1. Overclocking your eMac, Panel Removal: шаг 6, изображение 1 из 3 Overclocking your eMac, Panel Removal: шаг 6, изображение 2 из 3 Overclocking your eMac, Panel Removal: шаг 6, изображение 3 из 3
      • The motherboard access panel is held on by 4 phillips #2 screws.
      • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
      Спросите у FixBot
    1. Overclocking your eMac, Cables: шаг 7, изображение 1 из 3 Overclocking your eMac, Cables: шаг 7, изображение 2 из 3 Overclocking your eMac, Cables: шаг 7, изображение 3 из 3
      • To remove the fan assembly, several cables must be disconnected first:
      • 3-pin fan cable
      • Ground wire, requires phillips #2 screwdriver
      • 2-pin AC cable to power supply
      Спросите у FixBot
    2. Overclocking your eMac, Screws: шаг 8, изображение 1 из 2 Overclocking your eMac, Screws: шаг 8, изображение 2 из 2
      • Now remove the following screws securing the fan assembly:
      • 3x coarse thread phillips #2
      • 1x machine thread phillips #2
      Спросите у FixBot
    3. Overclocking your eMac: шаг 9, изображение 1 из 1
      • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
      Спросите у FixBot
    4. Overclocking your eMac, Assembly Removal: шаг 10, изображение 1 из 2 Overclocking your eMac, Assembly Removal: шаг 10, изображение 2 из 2
      • You should now be able to remove the fan assembly.
      • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
      Спросите у FixBot
    1. Overclocking your eMac, Bottom Connectors: шаг 11, изображение 1 из 1
      • There are four connectors at the bottom of the motherboard that must be removed.
      Спросите у FixBot
    2. Overclocking your eMac, Display Connector: шаг 12, изображение 1 из 3 Overclocking your eMac, Display Connector: шаг 12, изображение 2 из 3 Overclocking your eMac, Display Connector: шаг 12, изображение 3 из 3
      • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
      Спросите у FixBot
    3. Overclocking your eMac, Power Button Cable: шаг 13, изображение 1 из 1
      • The power button cable may be tucked in the casing, you will need to un-tuck it.
      Спросите у FixBot
    4. Overclocking your eMac, Screws: шаг 14, изображение 1 из 3 Overclocking your eMac, Screws: шаг 14, изображение 2 из 3 Overclocking your eMac, Screws: шаг 14, изображение 3 из 3
      • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
      • 2 large ones near the drive bay door.
      • 7 smaller ones scattered around
      Спросите у FixBot
    5. Overclocking your eMac, Screws (Continued): шаг 15, изображение 1 из 2 Overclocking your eMac, Screws (Continued): шаг 15, изображение 2 из 2
      • More of the screw locations from the previous step
      Спросите у FixBot
    6. Overclocking your eMac, Motherboard Assembly: шаг 16, изображение 1 из 1
      • The motherboard assembly should now come free.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Emmanouil Georgopoulos
Участник с: 03/15/11
115 Репутация
1 руководство автора
2 Комментарии к руководству
i am searching a POWER BUTTON for my old eMac(2004)
somebody can help me?
my email:cabanel.robert@orange.fr
thank you!
capitaine NEMO - Ответить Поделиться
Where is Overclocking ?)
Pavel - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 55
За всё время: 2,854
