Выберете то, что вам нужно
Unscrew the two screws circled in red.
Slide the plate in the direction of the arrow.
Unscrew the screw circled in red.
Lift the disk with the green tab.
Remove the disk in the direction of the arrow.
Disconnect the two connectors circled in green.
Remove the WLAN card.
Unscrew the four large screws circled in green
Unscrew the five small screws circled in red
Lift the cooler with the two tabs circled in blue
Pull the lever circled in red in the direction of the red arrow while pressing on it.
Unscrew the three screws circled in red.
Disconnect the framed connector in red.
Lift the flap that holds the two connectors framed in red.
Disconnect the two framed connectors in red.
To reassemble your device, follow the instructions in reverse order.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
