Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
How to fix a squeaky Water flow
Запчасти
Детали не указаны.
  1. Warning: Bevore working at it unplug the Power. Here you can see the plastic tube  from where the water comes. it is clipped in a claer plastic shape OPen the two clips an pull it down and shake it a little so teh tube can get out of it.
    • Warning: Bevore working at it unplug the Power. Here you can see the plastic tube from where the water comes. it is clipped in a claer plastic shape
    • OPen the two clips an pull it down and shake it a little so teh tube can get out of it.
    • This clear plastic is fragile, be careful or the clips may break.
  2. More pictures of the clear plastic part and its clipse. If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc. If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc.
    • More pictures of the clear plastic part and its clipse.
    • If you don't want to clean it you can skip this step. i used citric acid and a brush to clean it from calc.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. How to open - three steps: First step: remove the TWO PH2 screws on left and right sides. They have same length. Second step: PULL the complete display/touch-part for about one or two centimeters. rattel and shake a liitle because the flap to the icecrusher  could be frosted. Third step: Now pull it downwards and shake it a littlebit. On the left is the cable, it is not neccessary to unplug it. now turn around and you see the plastic from the lever.
    • How to open - three steps: First step: remove the TWO PH2 screws on left and right sides. They have same length.
    • Second step: PULL the complete display/touch-part for about one or two centimeters. rattel and shake a liitle because the flap to the icecrusher could be frosted.
    • Third step: Now pull it downwards and shake it a littlebit. On the left is the cable, it is not neccessary to unplug it. now turn around and you see the plastic from the lever.
  5. This is the backside. the quadratic black rubber part is the motorized flap of the icecrusher. be careful, ther are some springs, dont loose them.
    • This is the backside. the quadratic black rubber part is the motorized flap of the icecrusher. be careful, ther are some springs, dont loose them.
    • Now, Spray some Silcone-Spray on the moving parts. i have made red circles where i have put on the Spray. just a lille bit, also on the spring.
    • Try, move it, when its still noisy apply more silconespray while moving it in and out.
    • Thats it. reasemble, as last step clip on the clear plastic on the tube from the water, then the notches and then the clipse.
    • done :)
Заключение
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
2 участников успешно повторили данное руководство.
Schwarzstein
Участник с: 15.07.2013
2 418 Репутация
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 48
За всё время: 980
