PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement
Выберете то, что вам нужно
  1. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: шаг 1, изображение 1 из 2 PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: шаг 1, изображение 2 из 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: шаг 2, изображение 1 из 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: шаг 3, изображение 1 из 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: шаг 4, изображение 1 из 2 PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: шаг 4, изображение 2 из 2
    • Lift the Logic Board and remove the rumble motors from the base of the controller.
  5. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: шаг 5, изображение 1 из 1
    • The rumble motors are located in the bottom right and left hand corners of the controller.
    • Find where the power (red) wire and ground (black) wire are connected to the logic board. The power (red) wire should be on the left while the black (ground) wire is on the right.
  6. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: шаг 6, изображение 1 из 1
    • The soldering iron is very hot and can harm you or the device if used improperly.
    • Take the soldering iron after it has been heated up and place it where the ground (black) wire is connected to the logic board.
    • Let it heat up and remove some of the solder with the solder vacuum.
    • Do the same for the power (red) wire.
  7. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: шаг 7, изображение 1 из 1
    • Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
    • Take some solder and seal the hole so that the solder is completely covering the (+) hole.
    • Do the same for the ground wire.
Заключение
Еще один человек закончил это руководство.
Austin Miller
Участник с: 09/18/15
192 Репутация
1 руководство автора
Команда
IUPUI, Team 3-1, Harley Fall 2015 Участник IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 членов
Автор 5 руководств
Один комментарий
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
Josh Koontz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 2,669
