Введение
Caution: This guide includes using a soldering iron and can damage your controller or your hand if not used properly.
Выберете то, что вам нужно
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Lift the Logic Board and remove the rumble motors from the base of the controller.
Find where the power (red) wire and ground (black) wire are connected to the logic board. The power (red) wire should be on the left while the black (ground) wire is on the right.
Take the soldering iron after it has been heated up and place it where the ground (black) wire is connected to the logic board.
Let it heat up and remove some of the solder with the solder vacuum.
Do the same for the power (red) wire.
Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
Take some solder and seal the hole so that the solder is completely covering the (+) hole.
Do the same for the ground wire.
Еще один человек закончил это руководство.
Один комментарий
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
