PS Vita Slim Joystick Replacement
Выберете то, что вам нужно
  1. PS Vita Slim Joystick Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
    I actually broke a 32GB storage card because I didn’t remove it first before I open the chasis. Beware of this!!! REMOVE YOUR CARD FIRST!!!
    Daniel Wang - Ответить
  2. PS Vita Slim Joystick Replacement: шаг 2, изображение 1 из 2 PS Vita Slim Joystick Replacement: шаг 2, изображение 2 из 2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Joystick Replacement: шаг 3, изображение 1 из 3 PS Vita Slim Joystick Replacement: шаг 3, изображение 2 из 3 PS Vita Slim Joystick Replacement: шаг 3, изображение 3 из 3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Joystick Replacement: шаг 4, изображение 1 из 1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
    Don’t forget to remove the battery at this point. The little corners of the connector that poke out a bit are there for you to pry the connector up. Be careful pulling the battery connector out by the wire, you could damage the wire where it is attached to the connector.
    Landon Burnette - Ответить
  5. PS Vita Slim Joystick Replacement, Joystick: шаг 5, изображение 1 из 3 PS Vita Slim Joystick Replacement, Joystick: шаг 5, изображение 2 из 3 PS Vita Slim Joystick Replacement, Joystick: шаг 5, изображение 3 из 3
    • Starting with the left joystick.
    • There is a green casing holding in the joystick it will need to be removed to allow access .
    • There are 3 ribbons holding the section together. Remove them carefully.
    • Next unscrew the two screws holding down the casing. They will both still be 6.35 mm screws and will be able to be taken out by a J00 bit from the iFixit pro toolkit.
    • Now carefully left the metal piece holding down the green casing, it will be the last resistance. Lift out the green casing now.
  6. PS Vita Slim Joystick Replacement: шаг 6, изображение 1 из 2 PS Vita Slim Joystick Replacement: шаг 6, изображение 2 из 2
    • Once the casing has been removed there will be one more screw to be removed. It will be a 6.35 mm screws that requires a J00 screwdriver from the iFixit pro toolkit.
    • Now simply and carefully take out the joystick out.
    • With the joystick taken out you can now do what is needed on the left joystick, or even replace it.
  7. PS Vita Slim Joystick Replacement: шаг 7, изображение 1 из 3 PS Vita Slim Joystick Replacement: шаг 7, изображение 2 из 3 PS Vita Slim Joystick Replacement: шаг 7, изображение 3 из 3
    • Switching over to the right joystick.
    • There will be a green casing containing the joystick. First it must be removed.
    • Carefully remove the ribbons from the entire section.
    • Proceed to remove the two screws holding the casing down. They will be 6.35 mm screws and can be removed using a J00 bit.
  8. PS Vita Slim Joystick Replacement: шаг 8, изображение 1 из 3 PS Vita Slim Joystick Replacement: шаг 8, изображение 2 из 3 PS Vita Slim Joystick Replacement: шаг 8, изображение 3 из 3
    • Once the casing is off, there will only be one more screw to take off. It will also be a 6.35 mm screw that uses the J00 bit from the iFixit pro toolkit.
    • Now simply remove the joystick from the device .
    • Once the joystick is removed you can do what is needed to the right joystick part, or even replace it if needed.
Заключение
40 участников успешно повторили данное руководство.
Daniel Woodard
Участник с: 08/22/17
2 959 Репутация
Автор 7 руководств
Команда
Arkansas State University, Team S1-G2, Chamberlain Fall 2017 Участник Arkansas State University, Team S1-G2, Chamberlain Fall 2017
ARSU-CHAMBERLAIN-F17S1G2
4 членов
Автор 33 руководств
15 Комментариев
Would I have a problem if I used 2 screws for the right analog stick , it solved my ghost movement
Art Front - Ответить
I have changed the analog stick, but it is still not working
akash shah - Ответить
Can you switch left with right analog stick?
Pyro Haze - Ответить
yes you can switch them. but its recommended to get a pair of new analog sticks so you dont have to open it again when the other side fails
Darian Perisic -
Fixed, very easy! Thanks a lot
Julien Lemoine - Ответить
did it with a philips 00. Just be extra careful and push down hard so the driver does not skip and strip the screws. I would recommend getting a prying tool and plastic tweezers. I removed the casing by hand and removed and installed the ribbon cables by hand which took a while and was a big pain in the rear end.
Darian Perisic - Ответить
Gran ayuda por parte del autor: super fácil saludos desde Puebla México
Gustavo Cadena - Ответить
It should be noted, the battery is not secured to the case in any way and has a tendency to fly about if you’re not careful with it. I learnt this the hard way when it came loose and snapped one of its cables.
Sam Cain - Ответить
Just a note: the small green ribbons have little clips on-top that you can pop open to take them out and put them back in. If you’re experiencing some wonky connectivity you may need to go back in and re-secure them.
Stevie Dow - Ответить
Hey! Thanks for this. Was trying to figure out why removing the ribbons were so difficult. Appreciate you!
chris garcia -
Hey! Many thanks! This guide was very helpful and I finally got my PS Vita fixed after I had a broken joystick for about 2 years (which was the reason I stopped playing). One thing that was not mentioned in your guide was how to put the ribbon cables back into the connectors, which was my only problem. Eventually I figured out I had to pull out a small black plate on the connector so I can put in the cable (which wasn’t possible before). Anyway, thanks! =)
--- - Ответить
Very useful guide, found that mine had blue PCBs for the L/ R sides, however could be due to mine being a Japanese unit. I do recommend disconnecting the battery while doing this to keep from inadvertently powering the unit up.
I did have difficulty getting the ribbon cable for the rear touch pad re-seated properly. Found that I had to GENTLY bend the cable to make it easier to line up with its port on the mainboard.
Spencer Peat - Ответить
Anyone have recommendations as to who makes/sells reliable, good quality replacement joysticks for the 2000/slim series?
Having issues with mine drifting as soon as I boot it up, I'm gonna hit it with the contact cleaner (once I find where it's hiding), hopefully it helps, but since this was preowned, have to factor in wear and tear, so it might be easier to just replace them both.
Strings Cat - Ответить
Update:
Found a OEM styled part on amazon by a "Deal4GO", drift gone. Now I can experiment with the old stick at my leisure.
Strings Cat -
My PS Vita is no longer turning on after doing this, the orange light also does not come on when the charger is plugged in.
long_justifier - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 125
За последние 30 дней: 718
За всё время: 36,324
