PS Vita Slim Motherboard Replacement
Выберете то, что вам нужно
  1. PS Vita Slim Motherboard Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Motherboard Replacement: шаг 2, изображение 1 из 2 PS Vita Slim Motherboard Replacement: шаг 2, изображение 2 из 2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Motherboard Replacement: шаг 3, изображение 1 из 3 PS Vita Slim Motherboard Replacement: шаг 3, изображение 2 из 3 PS Vita Slim Motherboard Replacement: шаг 3, изображение 3 из 3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Motherboard Replacement: шаг 4, изображение 1 из 1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
  5. PS Vita Slim Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 PS Vita Slim Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • First you will want to remove the black casing holding the motherboard in.
    • Remove the two screws that are holding the casing down. These will be 6.35 mm screws that are to be removed using the J00 bit from the iFixit pro toolkit.
    • Once the screws are removed, carefully lift the case out of the system.
  6. PS Vita Slim Motherboard Replacement: шаг 6, изображение 1 из 2 PS Vita Slim Motherboard Replacement: шаг 6, изображение 2 из 2
    • Next remove the two bottom 6.35 mm screws using the J00 bit from the iFixit pro toolkit.
    • Now you will be able to gently remove the bottom casing.
  7. PS Vita Slim Motherboard Replacement: шаг 7, изображение 1 из 3 PS Vita Slim Motherboard Replacement: шаг 7, изображение 2 из 3 PS Vita Slim Motherboard Replacement: шаг 7, изображение 3 из 3
    • Next you must remove the two ribbon cables connecting the motherboard to other hardware parts. Please be careful. The third ribbon on the bottom is a camera that also needs to be carefully removed.
  8. PS Vita Slim Motherboard Replacement: шаг 8, изображение 1 из 3 PS Vita Slim Motherboard Replacement: шаг 8, изображение 2 из 3 PS Vita Slim Motherboard Replacement: шаг 8, изображение 3 из 3
    • Now gently lift the motherboard up, as there will be a ribbon that still needs to be removed.
    • Carefully remove the last ribbon, from the hardware and not the motherboard.
    • The motherboard can be successfully removed.
    • Any repairs or replaces will be doable now.
Заключение
9 участников успешно повторили данное руководство.
Daniel Woodard
Участник с: 08/22/17
2 959 Репутация
Автор 7 руководств
Команда
Arkansas State University, Team S1-G2, Chamberlain Fall 2017 Участник Arkansas State University, Team S1-G2, Chamberlain Fall 2017
ARSU-CHAMBERLAIN-F17S1G2
4 членов
Автор 33 руководств
Один комментарий
bonjour ma ps vita slim
batterie changé et la console a du mal a demarré quand elle s'allume comme si c'est comme elle a pas de batterie se remet a zero et apres on lance un jeu elle s'éteint et quand elle redémarre remettre heure c'est quoi le probleme
merci
Raymond Depardieu - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 44
За последние 30 дней: 161
За всё время: 9,112
