Введение
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guides goal is to help you replace your motherboard if anything is currently wrong with it. As long as you take your time and you are careful you should be able to complete the replacement process with any problems.
Выберете то, что вам нужно
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
Remove the two screws that are holding the casing down. These will be 6.35 mm screws that are to be removed using the J00 bit from the iFixit pro toolkit.
Once the screws are removed, carefully lift the case out of the system.
Next remove the two bottom 6.35 mm screws using the J00 bit from the iFixit pro toolkit.
Now you will be able to gently remove the bottom casing.
9 участников успешно повторили данное руководство.
Один комментарий
bonjour ma ps vita slim
batterie changé et la console a du mal a demarré quand elle s'allume comme si c'est comme elle a pas de batterie se remet a zero et apres on lance un jeu elle s'éteint et quand elle redémarre remettre heure c'est quoi le probleme
merci
