Danger
Потенциальная опасность
При несоблюдении этих указаний техники безопасности, может возникнуть травма. Будьте внимательны и следуйте всем указаниям.
Danger
Введение
To complete this repair, the user must possess skills in soldering, and proper tools needed to perform the repair.
  1. Remove the 5 screws on the back of the controller.
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. Remove battery by unlatching the battery cables from battery connector clip.
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. Remove the two screws holding the motherboard to the front controller housing.
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Prepare your station for the de-soldering of the charging port.
    • Prepare your station for the de-soldering of the charging port.
  6. To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard. First, used the desoldering pump to remove the solder from all 9 pins. Then, use the desoldering wick to remove any excess solder left on the motherboard.
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  7. After the charging port is removed, place the new charging port into position.
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  8. Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron. Solder the 9 pin connections that connect the charging port to the motherboard.
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
Заключение
To reassemble your device, follow instructions 1-3 in reverse order.
4 участников успешно повторили данное руководство.
Attak
Участник с: 04.12.2017
255 Репутация
1 Guide authored
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 5
За 7 дней: 48
За 30 дней: 204
За всё время: 1,475
