PS4 Dualshock 4 trigger reassembly
Выберете то, что вам нужно
  1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: шаг 1, изображение 1 из 2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: шаг 1, изображение 2 из 2
    • Remove these two triggers and springs from the backplate.
    • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
  2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: шаг 2, изображение 1 из 2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: шаг 2, изображение 2 из 2
    • On these two clips...
    • Push down the trigger until it clicks on both sides.
    • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
  3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: шаг 3, изображение 1 из 1
    • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
  4. PS4 Dualshock 4 trigger reassembly, Closing the cover: шаг 4, изображение 1 из 2 PS4 Dualshock 4 trigger reassembly, Closing the cover: шаг 4, изображение 2 из 2
    • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
    • Push down until it clicks everywhere.
    • Finally, screw in these four screws using a PH0 screwdriver.
Финишная черта
23 участников успешно повторили данное руководство.
Devnol
Участник с: 12/01/18
2 684 Репутация
Автор 5 руководств
3 Комментариев
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - Ответить
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - Ответить
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 94
За последние 30 дней: 454
За всё время: 39,837
