Выберете то, что вам нужно
That's my PSP. As you can see, the UMD door it's broken. It fell down when I was playing.
That's the part where the screws are located. You must move away the battery before doing nothing.
We must unscrew the screws marked with colour blue.
After unscrew the screws we can move away the front case.
This is the button board. In my case it's damaged.
This is one of the two clips which the button board has. With an oppener tool you should release it.
Lift the latch open, away from the ribbon cable.
Pull the cable away from the latch, and we are done! Be careful with the latch because it brakes easily!
Еще один человек закончил это руководство.
