Введение
This guide will show you how to remove the PSP's housing/frame.
Инструменты
Запчасти
Детали не указаны.
  1. Turn the PSP over so its back is facing you.
    • Turn the PSP over so its back is facing you.
  2. Locate the battery casing button on the rear-left side of the PSP. Press down the button and remove the battery cover.
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. Using your finger, remove the battery upwards from the system as shown. Using your finger, remove the battery upwards from the system as shown.
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Ответить
  4. Remove the four screws shown with a Phillips #00 screwdriver. You will have to peel back the guarantee sticker to access the screw on the lower left.
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Ответить
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Ответить
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Ответить
  5. Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. Gently separate the outer plastic casing from the rest of the system as shown. Gently separate the outer plastic casing from the rest of the system as shown.
    • Gently separate the outer plastic casing from the rest of the system as shown.
Заключение
32 участников успешно повторили данное руководство.
Henry Lee
Участник с: 14.01.2010
728 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 5-6, Forte Winter 2010 Участник Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 членов
Автор 14 руководств
Комментариев: 3
Thank you! Awesome help!
Jay Vee - Ответить
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Ответить
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 46
За последние 30 дней: 276
За всё время: 33,211
