PSP 2000 Analog Stick, D-pad and Action Keys Replacement
Выберете то, что вам нужно
  1. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: шаг 1, изображение 1 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: шаг 1, изображение 2 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: шаг 1, изображение 3 из 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Front Casing: шаг 2, изображение 1 из 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 3, изображение 1 из 2 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 3, изображение 2 из 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 4, изображение 1 из 2 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 4, изображение 2 из 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - Ответить
  5. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 5, изображение 1 из 2 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 5, изображение 2 из 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: шаг 6, изображение 1 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: шаг 6, изображение 2 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: шаг 6, изображение 3 из 3
    • With the PSP's faceplate removed, position the PSP so that the analogue stick is easily attainable.
    • Gently pull up on the analogue stick. It should just pop off from the rest of the device.
    • In order to clean it correctly, take a cotton swab w/ rubbing alcohol and clean the base of the analogue stick.
    • The connection point on the PSP should be done as well (where the analogue stick meets the PSP).
  7. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 7, изображение 1 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 7, изображение 2 из 3 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 7, изображение 3 из 3
    • Once the analogue stick has been cleaned, you may wipe the connection points of the D-pad and Action Keys from the PSP to the faceplate.
    • Next, with the faceplate turned upside down, locate the clear/white rubber backing of the D-pad to the left of the display window.
    • Gently peel back and proceed to remove the directional buttons from the faceplate.
    • Now is the time to clean the rubber backing and D-pad with rubbing alcohol, being sure to remove as much dirt and dust as possible.
  8. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 8, изображение 1 из 2 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: шаг 8, изображение 2 из 2
    • This process can also be done to the Action Keys (x, square, triangle, circle).
    • Locate the black rubber backing on the right of the display window and gently remove.
    • Again take a clean cotton swab with rubbing alcohol and clean away all dirt at dust.
    • Now might also be a good time to just clean the surface of the home bar and inspect the home keys if they have dust as well.
Заключение
27 участников успешно повторили данное руководство.
pepe32290
Участник с: 10/19/09
1 573 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-3, Maness Fall 2009 Участник Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 членов
Автор 35 руководств
5 Комментариев
Hi would you pls help check the screw spec ? thanks!
Jacky - Ответить
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, Laser Pointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
sophiefish -
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, LaserPointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
sophiefish -
Thanks! very helpful. I use it to clean the “X” button because don’t work. However, still doesnt work i believe is another issue.
Anyway this guide helped me a lot.
Alex - Ответить
HEY i helped traduce this guide into spanish at 100% and other of your guides in the traduction panel. I dont know if you need to accept them, i just let you know that there are at 100% thanks for the guide.
Alex - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 73
За последние 30 дней: 406
За всё время: 60,496
