Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Paint job scratched? Going custom? Change out your faceplate assembly!
Выберете то, что вам нужно
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the following screws from around the bezel:
Two 4 mm Phillips
One 5 mm Phillips
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
13 участников успешно повторили данное руководство.
