PSP 300x D-Pad Replacement
Выберете то, что вам нужно
  1. PSP 300x D-Pad Replacement, Battery: шаг 1, изображение 1 из 3 PSP 300x D-Pad Replacement, Battery: шаг 1, изображение 2 из 3 PSP 300x D-Pad Replacement, Battery: шаг 1, изображение 3 из 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Casing: шаг 2, изображение 1 из 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Ответить
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Ответить
  3. PSP 300x D-Pad Replacement: шаг 3, изображение 1 из 2 PSP 300x D-Pad Replacement: шаг 3, изображение 2 из 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: шаг 4, изображение 1 из 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: шаг 5, изображение 1 из 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
  6. PSP 300x D-Pad Replacement: шаг 6, изображение 1 из 2 PSP 300x D-Pad Replacement: шаг 6, изображение 2 из 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Ответить
  7. PSP 300x D-Pad Replacement, D-Pad: шаг 7, изображение 1 из 2 PSP 300x D-Pad Replacement, D-Pad: шаг 7, изображение 2 из 2
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
Заключение
4 участников успешно повторили данное руководство.
mbnewsom
Участник с: 10/28/09
3 103 Репутация
Автор 11 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 30
За последние 30 дней: 113
За всё время: 9,322
