PSP 300x Power Jack Replacement
Выберете то, что вам нужно
  1. PSP 300x Power Jack Replacement, Battery: шаг 1, изображение 1 из 3 PSP 300x Power Jack Replacement, Battery: шаг 1, изображение 2 из 3 PSP 300x Power Jack Replacement, Battery: шаг 1, изображение 3 из 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Power Jack Replacement, Casing: шаг 2, изображение 1 из 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Ответить
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Ответить
  3. PSP 300x Power Jack Replacement: шаг 3, изображение 1 из 2 PSP 300x Power Jack Replacement: шаг 3, изображение 2 из 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Power Jack Replacement: шаг 4, изображение 1 из 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Power Jack Replacement: шаг 5, изображение 1 из 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
  6. PSP 300x Power Jack Replacement: шаг 6, изображение 1 из 2 PSP 300x Power Jack Replacement: шаг 6, изображение 2 из 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Ответить
  7. PSP 300x Power Jack Replacement, LCD Screen: шаг 7, изображение 1 из 2 PSP 300x Power Jack Replacement, LCD Screen: шаг 7, изображение 2 из 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    The homebar has a little tab screwed in place under the screw that alsoholds the lanyard trim-piece on. You will need to unscrew that screw first and pry the lanyard piece up, to get the homebar out from under it.
    B McG - Ответить
  8. PSP 300x Power Jack Replacement: шаг 8, изображение 1 из 3 PSP 300x Power Jack Replacement: шаг 8, изображение 2 из 3 PSP 300x Power Jack Replacement: шаг 8, изображение 3 из 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Attention à cette partie où l’écran est un peu bloqué dans le coin inférieur droit, il faut donner un peu de jeu vers la gauche pour le décaler et le retirer plus facilement.
  9. PSP 300x Power Jack Replacement: шаг 9, изображение 1 из 2 PSP 300x Power Jack Replacement: шаг 9, изображение 2 из 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    For anyone struggling to get the screen’s smaller ribbon cable back in, don’t be too afraid to use tweezers to pull on the little tabs. It has to go in a good half way (of the darker area) in order for you to latch it without it falling back out.
    Tom - Ответить
  10. PSP 300x Power Jack Replacement: шаг 10, изображение 1 из 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Power Jack Replacement, Power Jack: шаг 11, изображение 1 из 1
    • Flip up the lock and detach the ribbon cable above the power jack.
  12. PSP 300x Power Jack Replacement: шаг 12, изображение 1 из 1
    • Remove the screw from the power jack.
  13. PSP 300x Power Jack Replacement: шаг 13, изображение 1 из 1
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    The plastic tab in this step is very fragile. Use care when bending the plastic tab back.
    Kris - Ответить
  14. PSP 300x Power Jack Replacement: шаг 14, изображение 1 из 1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
Заключение
7 участников успешно повторили данное руководство.
mbnewsom
Участник с: 10/28/09
3 103 Репутация
Автор 11 руководств
Один комментарий
Really easy to follow, thanks. You can dismiss the 10 and 11 steps being careful.
aONe - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 52
За последние 30 дней: 251
За всё время: 18,662
