Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
Remove the two Phillips screws holding the bottom plate.
Gently lift the bottom plate away from the device.
Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Use a plastic opening tool to gently flip up the analog joystick's cable connector.
Use your fingers or tweezers to gently pull out the analog joystick cable from its connector.
4 участников успешно повторили данное руководство.
