Введение
This guide will show you how to remove the drive cage from a Packard Bell 4X4 desktop so you can replace the optical drive, hard drive or floppy drive.
Запчасти
Никакие детали не требуются.
  1. Remove the 3 Philips head screws from the back of the computer using your Philips screwdriver.
    • Remove the 3 Philips head screws from the back of the computer using your Philips screwdriver.
  2. Using both hands on each side of the case, slide the top cover toward you. Lift it up off the computer.
    • Using both hands on each side of the case, slide the top cover toward you. Lift it up off the computer.
  3. The top cover is removed.
    • The top cover is removed.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  6. Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  7. Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  8. Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  9. Lift the drive cage up and out of the computer.
    • Lift the drive cage up and out of the computer.
Заключение
2 участников успешно повторили данное руководство.
Brandon S
Участник с: 04.09.2010
492 Репутация
Автор 3 руководств
Команда
Packard Bell Planet Member of Packard Bell Planet
Community
1 член
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 9
За всё время: 1,299
