Packard Bell 4X4 Desktop Optical Drive Replacement
Выберете то, что вам нужно
  1. Packard Bell 4X4 Desktop Optical Drive Replacement, Top Cover: шаг 1, изображение 1 из 1
    • Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
  2. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 2, изображение 1 из 1
    • With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
  3. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 3, изображение 1 из 1
    • The top cover is removed.
  4. Packard Bell 4X4 Desktop Optical Drive Replacement, Drive Cage: шаг 4, изображение 1 из 1
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  5. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 5, изображение 1 из 1
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  6. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 6, изображение 1 из 1
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  7. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 7, изображение 1 из 1
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  8. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 8, изображение 1 из 1
    • Lift the drive cage up and out of the computer.
  9. Packard Bell 4X4 Desktop Optical Drive Replacement, Optical Drive: шаг 9, изображение 1 из 1
    • Remove the 1 Philips head screw with your Phillips screwdriver. There should not be a screw in the right hole.
  10. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 10, изображение 1 из 2 Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 10, изображение 2 из 2
    • Slide the optical drive forward and lift it up from the right side, the side closest to the floppy drive.
  11. Packard Bell 4X4 Desktop Optical Drive Replacement: шаг 11, изображение 1 из 1
    • Remove the 2 Philips head screws with your Philips screwdriver. Put these screws onto your new optical drive.
Заключение
Еще один человек закончил это руководство.
Brandon S
Участник с: 09/04/10
490 Репутация
Автор 3 руководств
Команду
Packard Bell Planet Участник Packard Bell Planet
Community
1 член
Автор 6 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 1,056
