Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: шаг 1, изображение 1 из 2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: шаг 2, изображение 1 из 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: шаг 2, изображение 2 из 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: шаг 2, изображение 3 из 3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
Заключение
5 участников успешно повторили данное руководство.
Jasmin
Участник с: 02/17/16
407 Репутация
1 руководство автора
Команда
iFixit EU Team Участник iFixit EU Team
Staff
46 членов
Автор 1 095 руководств
3 Комментариев
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - Ответить
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - Ответить
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 27
За последние 30 дней: 97
За всё время: 7,361
