Введение
Step by step guide to disassemble the Palm Centro to replace the keyboard.
Выберете то, что вам нужно
Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
Lift the rubber cap at the top right to reveal the sixth screw.
Remove the six screws using the T5 Torx screwdriver.
Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
Continue with plastic pry tool all the way around the phone to remove the back housing.
Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
Slowly peel off the protective lining that is on the screen and keyboard.
Lift and slowly remove the screen from the front panel
Place the new screen into the front panel
Now that the screen is out and its electrical ribbon is not in the way, you can remove the keyboard by prying it free of the tabs that hold it in place.
Еще один человек закончил это руководство.
