Введение
This guide show you how to remove and replace the Palm Centro's speakers
Выберете то, что вам нужно
Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
Lift the rubber cap at the top right to reveal the sixth screw.
Remove the six screws using the T5 Torx screwdriver.
Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
Continue with plastic pry tool all the way around the phone to remove the back housing.
Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
Pry the four plastic latches free that connect the antenna to the logic board.
Remove the antenna from the logic board.
The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
Еще один человек закончил это руководство.
