Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
Hold the device on its side, positioning your hands as shown.
Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
Position your hands so you can push the screen outward with your thumbs.
Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
Remove cluster by pulling on the rubber backing.
Clean, repair, and/or replace as neccessary.
