Введение
The screen protects the camera from external damage, but in doing so can itself become damaged. This can be remedied by removing the screen and putting in a new one.
  1. Push in the button at the bottom of the phone, and lift the back cap off.
    • Push in the button at the bottom of the phone, and lift the back cap off.
  2. Remove the battery by pulling out the little tab.
    • Remove the battery by pulling out the little tab.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Using the 1.5mm hex screwdriver, remove the 6 hex screws from the inner-most casing.
    • Using the 1.5mm hex screwdriver, remove the 6 hex screws from the inner-most casing.
  5. Using the spudger, remove the inner case from the phone.
    • Using the spudger, remove the inner case from the phone.
  6. Now place your finger on outside of the screen and slowly apply pressure.
    • Now place your finger on outside of the screen and slowly apply pressure.
  7. While applying pressure, use your tweezers to remove the screen from the inner casing.
    • While applying pressure, use your tweezers to remove the screen from the inner casing.
Заключение
ironwill13791
Участник с: 30.10.2013
509 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G2
3 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 237
