Введение
Be careful with the screen if cracked, it may have sharp pieces.
Выберете то, что вам нужно
Pull the back cover from the bottom of the device and separate the interlocking tabs on the top to remove the back cover.
Looking at the back of the device hold one of the white tabs on the ribbon cable connector down and use tweezers to push in the other white tab toward the device at the same time.
The ribbon cable is now loose. Use the tweezers to carefully slide the ribbon cable out of the connector.
The screen is now disconnected from the rest of the device and can now be removed.
