Введение
This guide will show you how to readjust or replace the speaker if it is performing poorly.
Выберете то, что вам нужно
First the back panel must be removed to reveal the battery.
Remove the battery pack.
Remove the six T5 screws necessary to separate the backplate from the phone.
Additionally, there are interlocking tabs securing the back plate around the edges.
Use the opening tool to carefully go around the phone releasing these tabs.
Lift the metal flap marked in red to reveal the antenna connectors.
Carefully pry these the antennas from their connections, this can be done quite easily.
With the backplate removed, the speaker is visible.
Pry out speaker with spudger.
