Введение
Need to access the interior. Here's how to take off the case to do that.
Запчасти
Детали не указаны.
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
To remove the battery cover, hold down the button in the middle of the phone's back.
Slide the cover down to remove. Set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
Unscrew the screws around the back plate with a T5 Torx Screwdriver.
Six black 6.9 mm Torx screws
Unscrew the screw next to the antennae on the back plate.
One 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
3 участников успешно повторили данное руководство.
