Введение
The guide will demonstrate how to remove and replace a Palm Treo 650 microphone successfully. The microphone may need to be removed if the person on the receiving end of the phone call is unable to hear your voice.
Only begin this repair once the phone is disconnected from a power source and turned off.
Выберете то, что вам нужно
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the round, rubber cover to expose a screw that will be removed in the next step.
Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
