Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
How to access the motherboard for repair.
Выберете то, что вам нужно
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the round, rubber cover to expose a screw that will be removed in the next step.
Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
Pull off the mother board.
Install replacement or repaired motherboard, reversing steps above.
2 участников успешно повторили данное руководство.
