Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will show how to remove and replace the speaker from the phone shell.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  3. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • This will uncover a screw that will be removed in the next step.
  5. Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver. Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver. Pull out the antenna.
    • Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
    • Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
    • Pull out the antenna.
  6. Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
    • Pry the back cover off using a spudger or similar tool.
    • The back cover is attached by several small clips on the inside.
  7. Using an ipod case opener or similar tool, simply pry off the speaker. This may be glued in, so remove carefully.
    • Using an ipod case opener or similar tool, simply pry off the speaker.
    • This may be glued in, so remove carefully.
Заключение
cgood
Участник с: 28.10.2009
122 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 19-3, Maness Fall 2009 Участник Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,304
