Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows you how to take off the back panel to the Palm Treo 680 in order to reach the other components within side the phone.
Выберете то, что вам нужно
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device.
Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
Turn the phone 90 degrees to the right, so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone.
