Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows you how to take off the back panel to the Palm Treo 680 in order to reach the other components within side the phone.
Выберете то, что вам нужно
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Unscrew the 0.266 inch top-left screw using a T6 Torx screwdriver.
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
Unscrew the 0.266 inch screw using the T6 Torx screwdriver.
Remove the remaining two 0.266 inch screws at the bottom using the T6 screwdriver.
Turn the phone so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
Separate the covers from the left side of the device as indicated in the picture.
