Введение
This guide will show you how to easily remove and repair a dysfunctional Palm Treo 680 LCD Screen/Touch Screen with 4 easy steps.
Выберете то, что вам нужно
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Use a T5 Torx screwdriver instead of a T6. T6 is too big.
I found T5 too large as well. T4 seeems to work
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
Remove the 27mm screw using the T6 Torx screwdriver.
Turn the phone so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
Separate the covers from the left side of the device as indicated in the picture.
Locate the 2 small plastic flaps that hold the small orange ribbons in place on both sides. Using a small metal spudger, flip up both of the flaps.
Flip the screen over 180 degrees and take off the metal piece that cushions the screen.
Flip the screen over another another 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
Slightly start to pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are.
Move your thumbs to the other corner of the screen and slightly start to pull apart the touch screen from the LCD screen.
Carefully peel the touch screen away from the LCD screen.
Now you should have both the touch screen and LCD screen detached from one another.
2 участников успешно повторили данное руководство.
2 Комментариев
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Donde puedo comprar un telefono palm
lupem5635 - Ответить
Meurge porfabor
