Выберете то, что вам нужно
Press the button located just above the Sprint™ logo and then slide the cover down.
After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
Using the plastic opening tool, gently separate the back case from the phone body.
Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Once the motherboard is removed, the LCD should be resting on the front case of the phone.
