Введение
Follow this guide to gain access to your Treo's motherboard.
Запчасти
Никакие детали не требуются.
  1. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Use the small notch on the left hand side of the phone to remove the battery. Use the small notch on the left hand side of the phone to remove the battery.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Remove the stylus from the phone.
    • Remove the stylus from the phone.
  4. After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Using the spudger, remove the small rubberized patch under the antenna.
    • Using the spudger, remove the small rubberized patch under the antenna.
  7. Unscrew the last two screws using the previous screw driver.
    • Unscrew the last two screws using the previous screw driver.
  8. Using the plastic opening tool, gently separate the back case from the phone body. Using the plastic opening tool, gently separate the back case from the phone body.
    • Using the plastic opening tool, gently separate the back case from the phone body.
  9. Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  10. Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1). Once unscrewed, gently detach the antenna chip with your hands (Picture 2). Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  11. Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1). Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  12. To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Заключение
Ivan
Участник с: 29.04.2012
11 Репутация
1 Guide authored
Команда
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 членов
Автор 14 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 696
