Введение
If you know that your screen needs to be replaced, this guide will show you how to do so.
Выберете то, что вам нужно
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Carefully pull back the brown cable holders and separate the screen from the motherboard.
