Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the phone so it's facing screen-side down.
Slide the back cover upward to open.
Remove the back sticker.
Remove the three bottom Phillips #00 screws.
Flip the phone over so it's facing screen-side up.
Slide the screen upward by a few millimeters without detaching the screen.
Use the plastic opening tool to pry off the front panel.
Remove the bottom two Phillips #00 screws.
Remove the bracket.
Use the plastic opening tool to pry off the speaker.
Remove the Philips #00 screw
Remove the sliver metal piece
Remove the Philips screws #00
Remove the rear blue panel by prying both sides using the plastic opening tool
Remove the black plastic sticker
Pull the tap up to remove the metal cap
Remove the cable by pinching the sides and pulling
Pry off the battery with the plastic opening tool
Insert the new battery
7 участников успешно повторили данное руководство.
