Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will provide instructions and visuals to removing and replacing batteries.
  1. Take the battery cover off by pushing down on the tab and lifting off.
    • Take the battery cover off by pushing down on the tab and lifting off.
  2. Make sure batteries are there.
    • Make sure batteries are there.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Check the type of batteries to be sure they are both AAA batteries.
    • Check the type of batteries to be sure they are both AAA batteries.
    • Make sure they are installed in the right direction by taking the batteries out, aligning the positive side with the positive side and the negative side with the negative side.
  5. Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • If the device still does not turn on, repeat the previous steps with a fresh set of AAA batteries.
Заключение
Anne Carey
Участник с: 25.10.2011
1 Репутация
Автор 3 руководств
Команда
James Madison, Team 1-3, Allen Fall 2011 Участник James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 517
