Palm m105 Button Replacement
Выберете то, что вам нужно
  1. Palm m105 Button Replacement, Buttons: шаг 1, изображение 1 из 1
    • Begin with the Palm m105 facing you on a flat surface.
  2. Palm m105 Button Replacement: шаг 2, изображение 1 из 1
    • Remove the protective screen cover by flipping it up and pulling it directly away from the top of the device.
    • The two clips located on the protective screen should pop out.
  3. Palm m105 Button Replacement: шаг 3, изображение 1 из 1
    • To remove the faceplate, lift the tab located at the top of the device.
    • The faceplate should easily lift off.
  4. Palm m105 Button Replacement: шаг 4, изображение 1 из 3 Palm m105 Button Replacement: шаг 4, изображение 2 из 3 Palm m105 Button Replacement: шаг 4, изображение 3 из 3
    • Using a T-5 Torx screwdriver, remove all four screws located on the back of the device. Turn counterclockwise to remove screws. The link to purchase this screwdriver is located at the top of this page.
    • Once you have removed all four screws, the device will be in three separate pieces (the back, the computer, and the button board).
    • Take caution as the power button will become loose after this step is completed.
  5. Palm m105 Button Replacement: шаг 5, изображение 1 из 1
    • After step four, locate the button board. The button board should have a frame attached to it. Remove this frame.
    • To remove the buttons from the frame, apply even pressure on two buttons at a time. This should make them pop out easily. Once you have removed the buttons, you can now wash or replace them.
    • To insert a new set of buttons, push it back into the opening on the faceplate, and you should feel it click into place.
Заключение
Еще один человек закончил это руководство.
Erik Thompson
Участник с: 10/04/11
31 Репутация
Автор 5 руководств
Команда
UW Stout, Team 1-3, Zhou Fall 2011 Участник UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 14
За последние 30 дней: 51
За всё время: 529
