Выберете то, что вам нужно
Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
Remove the cover by lifting it from right to left.
This should be similar to the action of the opening of a book.
Gently disconnect the white component connecting the battery to the motherboard.
Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
Disconnect the orange video connector leading from the lower case to the upper case with the pointed end of the spudger.
Use the spudger to unclip the screen in the lower left corner and gently pry it from its clips.
Grabbing the left and right edges of the front panel, flex the front panel outward until the screen pops out.
